Brief Description: R F/Tank: Filler Camp, Drain Plug and Cap.plates
Aligned and fitted the filler cap as per the left wing, and match drilled using the skin as a guide. Then fitted the drain plug using the same method as per the left tank (red koki plen) and drilled the skin using the overflow as a guide. I then fitted the capacitance plates and removed matgerial as per spec to maintain published clearance from skin and stiffeners.
