Brief Description: F/Tanks: Inboard Bay Trap Door (Left)
Completed the trap door for the left Rib as per the right. I added a little tab so that I could secure the hinge pin in such a way that it is removable (who knows). Most others have bent the hinge pin in such a way that it'll nevery come out without removing the entire tank bahhle (back plate)
Trap Doors Fitted
Hinge Pin bent such that it can be removed should the need arise
