Gary's RV8 Construction Log
Date:  10-7-2010
Number of Hours:  1.00
Brief Description:  R F/Tank: Countersink skins
I removed the right fuel tank from the wing spar and double checked the positioning of all the holes drilled into the z-brackets to make sure there were no edge disyance issues. Everything was spot on - this method of drilling the z-brackets is definitely superior to that of Van's.
I match drilled the right skin to the understructure and the started countersinking the skin (not the baffle) at all baffle attachment holes as per instructions.
Z-Brackets drilled perfectly
Right fuel tank match drilled
Countersinking skin for all baffle attachment holes!
