Cleaned and "Brightened" the metal as preperation for priming with AQL's bare metal cleaner. Each part is then washed down thoroughly in water in water and left to dry. Once dry, the spraying of the primer itself is probably the quickest job of the lot!
The only place I struggled was the inside of the rudder skin, having had the trailing edge allready bent, it was difficult to get in there with a decent finish. A bit of patience and some perseverance though and it all turned out well in the end.
Now to start the assembly...
Rudder parts lying on the spray table waiting to dry
