Brief Description: L-HS & L-Elev Tips: Sanding and floxing
After checking that all had cured properly, I removed the pieces and plugs and sanded down the respective parts. I then mixed up a batch of flox and made a gusset on the inside of the HS-Tip.
Once happy wth the gusset, I added some micro ballons to the flox mixture just to "fluff it up" a tad and then applient that to the exterior of the L-Elev tip to build it up appropriately. Left to cure.
Parts and plugs removed with first rough sanding complete
Flox gusset inside L-HS Tip to strengthen joint.
Flox and micro mixture applied to L-Elev tip to fill up and shape part.
