Brief Description: L-Elev: Complete understructure, match drill, debu
Continued with the construction of the understructure. The control horn rear spar for the trim tab were constructed and final drilled. Thereafter, all was dis-assembled and everything (skin and understructure) had the edges finished (filed and scotchbrite wheel to smooth it out) and all holes were deburred. Once again, the cogsdill deburrer making short work of the process.
The left elevator is really moving along quickly!
Continuing with understructure assembly - WD605 control horn in place
Understructure assembly completed and skin match drilled
Left elev disassembled and skin and understructure deburred
