Brief Description: L/E: Drilled platenuts on Joint Plates
I dimpled the joint plates appropriately with the pneumatic squeezer. I then drew lines on the to assist in centering and aligning the platenuts. I match drilled the joint plate using the platenuts as a guide and then deburred and dimpled the jointplate to platenut rivet holes. I dimpled the platenuts using the Avery small diameter dimple die.
