Gary's RV8 Construction Log
RV-8
L F/Tank: Fitted the vent pipe
I straightened an appropriate length of Alu tubing and bent two 45 deg bends such that the vent pipe sat perfectly snugle on the corresponding fitting on the inboard rib without needing to be tightened.
Fitting the vent pipe
Bent as per spec and fitting snuggly
RV-8 Home
414
134
Fiberglass: Emp
Other
212
Workshop
