Brief Description: L F/Tank: Flop Tube anti hang-up
I built an anti hang-up bracket as per spec for the installayion of the flop tube. This bracket is meant to prevent the flop tube getting stuck in the hole hole in the rib by stopping it ever getting there. I also made it with a bit of a bend on the top to stop a stright edge of the metal cutting into the flop tube over time - probably not an issue but it's done!
