Brief Description: R F/Tank: Manufactured vent pipe clamp
Manufactured the clamp for the overflow/breather pipe on the right fuel tank. I used the same process as per the left tank which was basically to wrap a pre-cut peice of aluminium around the shank of a 1/4" drill bit. It worked like a charm and I ended up a very neat snug fitting clamp.
Wrapping the Alu. around the shank of a 1/4" drill bit
Perfect shaped clamp
Finished clamo cleco'ed in place on the fuel filler
