Gary's RV8 Construction Log
RV-8
Z Brackets-Fitting & drilling to Left Fuel Tank 4
... continued ...
With the baffle now securely in place, I removed the fuel tanks skin. If only it'd go together as easilty as it came apart!
The entire tank baffle now exposed, match drilling the rest of the Z brackets using the baffle as a guide was a simple process.
Z Brackets for the left wing all done!
Fuel tank skin removed
Match drilling z brackets using tank baffle plate as a guide
All left tank z-brackets drilled
RV-8 Home
414
134
Fiberglass: Emp
Other
212
Workshop
