The Engine Intake Diffuser was designed in Solidworks and layers of foam blocks were cut out on a CNC router and glued together. This will have 4 Layers of Carbon layed over the Plug and then the Pulg will be dug out and removed. I will then have to build a lower door on the Diffuser so it can be insatlled and removed from the Engine over the Starter without having to remove the engine from the Motor Mount.
