Brief Description: Worked out the 24V Electrical System
Catch up Entry...I tried using Facebook as a log but that didn’t work out so great with Facebook blocking my Log Book account so I gave up on them and going back to KitLog.
The T58 Takes a LOT of amps to crank and if you try to start it without enough voltage you WILL get a Hot start. So I plan on using 4 Optima RedTop Batteries. See the Schematic below for the layout
