The Joyce Family RV-7A
RV-7A
Vertical Stab
Work on the Vertical Stab
Worked on the vertical stab today. Everything is fabricated, test fit, deburred, dimpled, prime'd and ready for final assembly. I'm only using primer on the inside contact lines on the skins since the sheet is alcad.
Match Drilled
Primered & some rivets
Just the contact lines primered
RV-7A Home
Paperwork
Practice Projects
Shop Prep
Wing
