The Vestal White Jet Glo was applied today. We spent most of the time in prep work etc. We used the recommended 2 coat process. As can be seen from the photos, the surface has a porceline finish with very little surface variation. Next step is the Flight Blue on the lower sides and bottom. The cowling will be attached prior to painting. I was very pleased at all the body work we did prior to taking it to the paint shop. The front windscreen taper turned out especially well.
