Brief Description: Primed Wheel Pants and Fairings
We had a little down time waiting on the prop hub we borrowed to fit the cowling. So we decided to work on finishing up the wheel pants and fairings. We started by sanding the pieces with 120 then 320 grit, then using an epoxy primer/sealer PPG DP48LF. This was followed by PPG K36 filler primer. We now need to block sand all of the parts and then they will be re-sealed prior to paint.
