Over the past couple of weeks we have been focused on finalizing the engine installation. We have re-installed the baffling, hooked up the ignition system, routed the plug wires and installing the oil cooler, fuel servo and all associated plumbing. We had to re-order new Prop, Mixture, and Throttle cables in a longer length to accomodate the Aerosport Panel installation. We fabricated a bracket for the fuel flow transducer and also mounted the Slick Start ignition boost on the firewall.
