Aviation Partners, LLC Project
Date: 10-29-2011
Number of Hours: 22.00
Manual Reference: None
Brief Description: Panel Checkout
I spent the whole weekend checking every one of the panel out/input connections which pass through the firewall from the GSU 73 processor connect J732.. I set up all of the wires on the workbench, stripped the insulation back, tapped them down and then attached sensors for EGT, CHT, Fuel Level, Fuel Flow, Fuel Pressure, Manifold Pressure, Oil Pressure, Oil Temp Main bus current, Aux bus current, RPM, Alt Field, Alt Fail Line, Oil Pressure Fail Line, and any others that I forgot. I stimulated each sensor. All tests were a success and all lines worked properly. The avionics were again removed from the panel and it is now ready to be installed in the fuselage!
