Brief Description: Installed the Aerosport Rudder Trim
We installed the Aeropsport Products rudder trim system. We mounted the drive gear directly behind the front panel and to the left of the throttle lever. The actuator arms were attached to the rudder torque tubes using the hardware provided. I have a concern with the actuator arm slipping on the torque tube shaft.
