I worked on cleaning up the air inlet. I used a small piece of the FAB as the outlet. The lower baffle material will wrap around the bottom and sides of the cowl side and the top baffle is attached to the FAB. This allows easy removal of the cowl as there is no interference with the lower baffle as when it is attached to the FAB. This allowed for a tighter seal. The baffling was installed, but is now removed in the photo. The entire inside of the cowl will be painted and further work will be done in preparation for that.
