Brief Description: Began re-assembly of cabin cover
This entry covers 2/1-12/3. We re-installed the cabin cover and prepared for pernanent installation. The center brace was installed and the coax and wiring was run up the center. 2 LED lights were installed in the overhead console. In addition, both the GPS antennas were installed. The GNS430 was mounted directly between the cabin doors in spite of the fact it will cause some drag, it was the only flat area on the top of the aircraft that was far enough away from the upper comm antenna which is mounted directly behind the cabin cover. The GPs/XM weather antenna was installed offset of the center line and at the rear of the overhead access panel. Both antennas were installed with a .062 doubler plate on the inside of the cabin.
