Brief Description: Finished trim on glass in Left Door
I put the final touch on the black trim inside the door by painting a band of semi gloss PPG inside the window. This looks shiny when viewed from the outside. The black primer acts as a UV protector and provides a contrasting frame for the window. The outside edge of the glass will get a pro-seal gasket after the plane has been painted. This method of window installation is the same as the Cirrus SR22 install. . Now that I have the process down, the next 4 windows will go a lot easier and quicker. I will paint the trim band in advance of the adhesive.
