Brief Description: Began final fitting and prep of door windows
Final sanded both the left and right windows for the associated door panels. Bonded spacers to raise glass to flush with door. We will be using the Sikaflex adhesive process which amounts to a three step process. First applying the activator, then the black primer to both surfaces, then the adhesive.
