Brief Description: Finished Primer on outside of doors
This covers 5/3 - 5/5/2011. Over the past three days we have focused on finishing th outside of both of the doors prior to installing the windows. I wanted to have a white base coat around the window joggle, this will help with the plan for using a Sika adhesive with a black activator to be painted on the inside of the window glass. The Sika adhesive is black as is the activator, which will give each window a 3/4" black border. The area between the window edge and the joggle will get final paint and then be filled with Sika adhesive making a finish bead.
