Brief Description: Completed primer of door inside panels
This entry is for the week 4/25 thru 4/29. We removed all the latch hardware and began the task of finishing the inside of the left and right door assy's. First we coated each door with 2 skim coats of epoxy resin. This was followed by one coat of "Feather Fill" surfacer build filler. Followed by a lot of sanding, then a coat of PPG DP48 epoxy primer. The next step is applying the final paint to match the interior panels. I did not get a photo of the competed final primered door.
