The QB kit comes with the floor panels temprorarily POP riveted in place and needed to be removed. Unfortunately, the front floor panels can not be removed without either removing the landing gear attach fittings, or cutting the panels out. After cutting the panels out a new panel insert was constructed of .025 material, these two pieces will be installed after the primer and soundproofing are installed under the front floor.
