Nigel & Nicks RV-7
Date: 3-18-2017
Number of Hours: 1.00
Manual Reference: DWG 6
Brief Description: Vertical Stabiliser - Countersink and Dimple
Mark the location and orientation of VS-803PP, VS-411PP and VS-412PP. Disassemble, de-burr, dimple, machine countersink and prime parts as desired (See “Countersinking”, “Dimpling”, “Hole Deburring” and “Priming”, Section 5.1, 5.2, & 5.5).
Note as shown on DWG 27/27A the lower portion of the rear spar must lay flush against the F-712/812 bulkhead assembly. Therefore the rivets in this region must be flush on the forward side of the rear spar that mates to the F-712/812 bulkhead (See Rear View, SEC A-A and “Countersinking and Dimpling”, Section 5.5).
