Andrew & Neils Web Site
Date:  4-22-2014
Number of Hours:  10.00
Brief Description:  Fuel system
Fabricate main fueltank breather tube, including visual overflow filter and made and assembled lines.
Mount and seal filler neck to turtledeck skin.
Finnish off parkbrake cable connection to park brake valve.
Bleed brake systems.
Fit stabilator trim wiring pins to fuselage harness plug at dash connector.
Fit external GPS power and audio sockets in dash lower tray exiting under dash.
Add and tighten all dash facia pannel screws.
Fit and connect Dynon Skyview unit to dash pannel.
Refit upper dash pannel sealing the seating area to the firewall with silicon as per SB
Modify the aileron floor access pannel to allow fuel tank to remain installed in the aircraft.
Fit fixed portion of the rear cabin access hatch.
Install battery.
Fabricate new earth busbar to battery earth using 6 guage wire.
