Fit flaperons to wings. Readjust hinge heights to correct height of 11/32 to centre of the hinge eyebolt.
Trial fit wings to fuselage. had a few minor problems, had to loosen both nylon giude blocks to allow spar pins to engage fully Inner fuselage side channel skins interfered with the spars and needed to be trimmed to clear. Drilled off flaperon drive connect tubes.
Starbord wing has approx 1mm excess clearance in the front spar receptical Port wing has approx .015" excess clearance.
