Andrew & Neils Web Site
Date:  3-7-2014
Number of Hours:  7.00
Brief Description:  ADSB unit and USB power
Install ADSB kit to aircraft.
Module had to be installed on the top of the map box. 2 angle stiffner brackets also fitted to strengthen mounting point on map box.
Mounted and wired in the fixed USB power supply and Circuit breaker into the dash Tray to exeit under the dash.
Cut holes in dash facia pannel to mount fuelpump isolation switch and Low voltage indicator lamp.
Add wirining and modify existion fuel pump wiring.
