I finally figured out where to install the fuel flow sensor. The aluminum line from the fuel servo to the flow sensor will be replaced with stainless. The tip of the bracket is barely touching the cowl. I will have to pull it all back off and trim the bracket. I have not wired it up just yet. I want to make sure that is its final resting place.
