Between yesterday and tody, I am guessing 20 hours. I installed the Stark avionics harness. Everything went well. I have powered up the audio panel to test the intercom, good to go. I ran the AFS audio file test. I have sound. I stll need to wire up the ARINC-429 converter ( I don't have it yet). I will have to bust into the Garmin 430W harness and add one pair of wires, ARINc input. This does not look to terrible. It is just another one of those exercises. Everything that will power up, works. I do have a bad flash tube on the tail. I'll have to check into the waranty on that. I have been powering it up at least once a month to keep it evercised.
