Alton's Web Site
Date:  9-20-2007
Number of Hours:  12.00
Brief Description:  Cut out the left panel
I cut the left panel with a fly-cutter and a jigsaw for the big square hole. Dressed up all the edges with a jeweler's file and emory cloth. I am happy with the results. The two open 2 1/4" holes will get a trutrak auto pilot and a trutrak ADI.
A Tour:
The LEDs on the left are for the Gretz heated Pitot tube.
True airspeed
AFS-3500EE
Altimeter
Garmin CDI (will be driven by a Garmin 430W)
Switches:
Top left
Plasma 3-1, Plasma 3-2 (dreaming at this point)
Start, Alternate power source for right Plasma (If installed)
Bottom, left to right
Master
Fuel pump
Pitot heat
Strobe lights
Nav lights
Landing light 1
Landing light 2
Panel light and dimmer ( two led map lights pointed at the panel)
Instrument lights and dimmer (Airspeed, altimeter, CDI, and avionics stack)
EFIS 1
EFIS 2 (more dreaming)
Auto Pilot
Alternate source of avionics power
My down the road plans are to have a B/U alternator to feed avionics and Electronic ignition (way down the road, I still need an engine). I think I will start with a small B/U battery for the EI. The EFIS already has a B/U battery.
