Brief Description: bolted on the canopy to the frame.
Today, I bolted the canopy to the frame. After that, I rivented the side skirts to the frame.
I worked on the safety catch for the canopy. I scored a spring from the Ace hardware aviation ailse. Now, it is srping loaded. you have to pull down and rotate to set the catch. There is no way it can accidentally be bumped and latch the canopy with no one inside. I brazenly stole this idea from VAF.
