Today was a very productive day. I cleco'd on the bottom skin on the left wing and pushed it out of the way.I got started on the right wing. This is going to go quick. I have done all of the prep work to the spar, rear spar, and ribs.Today, I final drill all skins, with the exception of the tank skin. The outboard leading edge is ready to be taken back apart. I fabricated the joiner plate for the tank and leading edge assy. I drilled the spar side of the z-brackets for the tank using the Checkoway method. Tomorrow, I will a cleco the right tank together and finish drilling the z-brackets.The down side to making all of this progress: I have a weeks worth of debur, dimple, prime. Now there is something that gets old.
