I set up to do the pressure test. The first leak was on the cork gasket. I installed this just for the leak test. I plan on removing it and prosealing the inpection cover prior to installing the wings. From all I have read, this seems to be the way to go.The second test revealed the BNC connector. It was leaking from the center. I removed the inspection cover and gooped some proseal on it. Pressed it back up and all appears to be well. As the tank heats up, the level in the manometer is actually rising.One thing to note: when you press up the tank, and then start to spray a soap solution on it to check for leaks, this cools the tank. The manometer level will fall due to this cooling.
