I routed the engine cables (prop, throttle, mixture) and installed the exhaust system. I still need to figure out the exhaust hangers and the heat muff. The Prop governor sucked. I had to take it off and rotate the control, seal wire, repeat. I didn't get it rotated far enough the first time. I now have full throw. Van's said in the instructions that you could not get full throw.
