Brief Description: Two steps forward, one step back.
Today, I started removing ALL of the inspection covers. Mostly done, still need to complete the tail section, wing root, and a few more wing inspection covers.
I decided I did not like the pilot's stick position. It was leaning a little to the left. I adjusted the left aileron pushrod and fixed that, Then I had to adjust the right aileron back to neutral. Not so easy. The pushrod adjustments left minimum thread engagement. I just happen to have the materials to fabricate a new push rod. Done. I temporarily installed to check the results. Good to go. Tomorrow I will bolt it all back up and torque it.
