Ever since I hung the wings, the elevator push-rod has been rubbing through the fuselage bulkhead. Today, I pulled it all out and relieved the opening just enough to clear the pushrod. While I was at it, I installed the Trutrak mod to the servos. I checked every inch of the controls. The ailerons and flaps are rigged. The wingtips are installed and lineup just great with the ailerons. I started working on the prop spinner filler piece behind the prop blades. I am going to have to dig deep in the scrap box to come up with some .032 Al.
