AARON'S WEB SITE
Date:  11-15-2013
Number of Hours:  1.00
Brief Description:  Installed capacitive senders on right tank
I installed the capacitive senders in the right tank today. I started by using a drill to modify the snap bushing to accomidate the wire. I then stripped crimped and soldered the connections. After that was verified witha 20lb pull test I started assembly by feeding the wire, inserting the fuel vent tube and then attatching the hardware. Electrical isolation has been verified, however this will need to be done again once the wire has been soldered to the BNC connector on the end rib.
The connections still need a filet of sealant as well, this will occur when the end ribs get installed.
