Brief Description: Tank end rib fitting install - prep
After reviewing my previous work I decided that I wanted to add two more rivets to the 410 attachment bracket on each tank end rib. The large rivets were very difficult to set well, a couple in each end rib knuckled over. I setup my drill press in a way that allowed me to compensate for the angle of the nose of the rib and drill holes perpendicular. I also prepped the AN fittings for completion later.
I was going to do some actual building(beyond drilling 4 holes) today, however I just learned of the death of my uncle and spent part of my day making plans to attend the funeral. That being the case I was having a hard time concentrating and I decided to prep for the next working session rather than build without being able to dedicate my attention to the task at hand.
