Brief Description: Riveted in the rear spar and finished the VS
Dick Socash came over to help on KT this afternoon. Dick took me for my first(and only) RV ride in his RV7.
He helped me finish rivetting the top rib, bottom rib, and nose rib to the VS skin and then we riveted the rear spar on. Most of the work was done with the pnuematic squezzer. There were a couple of rivets on the spar that made it really hard to use the squezzer, and a few I ended up drilling out and redoing(the same rivet on either side of the VS). In a couple of spots the rear spar's rivets got in the way and I had to hand buck, this also occured near the brackets for the rudder.
