AARON'S WEB SITE
Date:  12-27-2011
Number of Hours:  3.00
Manual Reference:  6-5
Brief Description:  VS/dimple/countersink and started on the rudder
I dimpled and countersunk the spar and then dimpled all the ribs and forward spar for the VS. Once I dimple the VS skin it will be ready to set aside for priming.
I started on the rudder today as well. I cut all the stiffeners for the rudder, and edge finished them. The edge finishing took a while, I used the scotch brite pad on the grinder wheel. I then fit the first side of the rudder with the stiffeners and drilled. The second set of stiffeners are on the bench and still need to be drilled.
