AARON'S WEB SITE
Date:  12-26-2016
Number of Hours:  2.50
Brief Description:  Installed push pull for heat, air, and alt air
installing the 3 push pull cables was rather straigh forward once the location was decided on. I placed the alt air on the left gear tower infront of the throttle. The push pulls(2) for the heat and air went on the right side above the switch panel.
The only hickup was the getting the nut onto the push pull cable, the small piece of safety wire on that catchs the detents was not wound tight enough to allow the nut to come off. I had to take all three cables and rewind the piece of wire tighter.
