Brief Description: Passenger footwell rivetting & other misc
Passenger footwell riveted together, rivets the top of the F808 to the lower section including the bracket for the pitot T. I installed the 4 rivets that are under the bell crank rib. Installed and torqued to spec the lower pushtube at the bell crank, then installed and torqued the bolts for the bell crank.
I wired the postive terminals of the two fuel pumps as they will be more difficult to get to once I install the pump onto the support bracket.
