Brief Description: Wrap up of rear throttle and start of electric ale
Soctt and Dale started by validating the install of the rear throttle since I had opened up the holes for the linkage. They discovered that the travel was limited because the hole inthe fwd throttle wasn't drilled perfecty in the center. A little filling of the clevis and it has full travel. Next the replicated the cover for the throttle on the other side of the fuselage.
Once that work was complete they started to work on the electric aileron trim.
