I started my day by installing the nutpaltes on the fwd seat ramp so that I can put in the recently delivered seat foam....you gotta sit in the plane and make noises to see if you need a thicker or thinner seat.
I then set to work creating carbboard cutouts of the LRU's that will go in the FWD avionics bay.
Cliff and Scott came over as I was cutting out the LRUs, I set them to work making the F863-1(l&r) brackets. They cutout the rough shape on the bandsaw them went to Cliffs shop to finish the parts.
After they left I did some work designing the heating cooling system for the front of the plane. I'm going to put a Y at the fresh air NACA, this Y has a valve in it I can close to reduce the airflow to almost 0. I'll use that valve along with the heatbox valve to mis the proper heat/cool temp for the plane.
