Brief Description: misc fuse work in prep for turtle deck riveting
Rivetted nutplates for rear baggage area access panel. Riveted the rear seat bulkhead top to the bottom. Installed and troqued to spec the 6 bolts holding the rear seatbelt attatch points. Rivetd some of the left side cockpit rail near the fwd end as the rivets would be hard to get to with the Pitot static line running from the aft to the fwd instruments. In the process of drilling out a rivet my bit broke, sending the broken end still spnning onto the rail!!! it left enough of a scratch that I've removed the paint and sanded down the scratch. I masked off the area and repainted the area. If this is any indication future patches/fixes should be no big deal
