AARON'S WEB SITE
RV8
misc fuse work
I drilled holes under the longerons to run the pitot line from the stasic ports at the rear up to and through the panel on the left side.
I tinkered with the battery box area, trying to assess the best fit for the area. I then drilled holes in two of the firewall penetraions.
I also bolted the F864E-1 to the throttle bracket.
RV8 Home
738
128
Fuel Tanks
266
Practice Kit
Side Projects
195
