Brief Description: Trim firewall penetraion for left side
I needed to trim the flange of the firewall penetraion as this one will go on the left side fo the fuse right up against the cowling. This will likely be the pass through that carries the thermal couple wires for the CHT/EGTs.
Since it's stainless I used the grinder with a cut off wheel to cut the edge then the grinder for final trim
